Alright two questions:
1. the 30-0-30 lines into a rectifier round out to 41.32 after rectification and voltage drop, the 1.32 extra volt won’t damage the +/- 40 lines? That small bit of voltage is ok?
2. If I tap off a line from the 24v line and use a voltage regulator for an 18 volt line to run another circuit in the amp, The amp should function? I don’t need to change the amp to run that single 18 volt line? As in changing
Power section or the power transistors?
