could someone derect me to a sch# layout and partslist for a first time amp build. ive got all the parts or at least most. to start a build a small 3 tube champ ore something like it. id like to get started on a project
first diy build help
Here's the link for a champ.... http://ampwares.com/amp.asp?id=42
Is that what you are looking for?
Marc
That might be a bit too complicated for a first timer.
I'd try this one:
http://ampwares.com/amp.asp?id=1
or this one if you want a tone control too:
http://ampwares.com/amp.asp?id=71Last edited by Bruce / Mission Amps; 10-26-2008, 06:26 PM.
Originally posted by mark enger View Posti have a small pa from m-g from the 50s. its got 5y3 6l6 and a 6sc7 should i gut most of it and wire in the prinston. id replace the 6l for the 6v6 and put in a12at7 i have does that sond right. could i run the the same bias.
If the amp was made for a SE 6L6, then I'd use that tube too.
Look on ebay (or local) for an old 6L6 coke bottle tube for a real vintage sound with very simple rewiring of the chassis you have.
