Cap can vs axial lytic caps
  • Cap can vs axial lytic caps
    Building a Princeton Reverb. Power supply has a 4x20uf cap can. Is it better to have the can type or can I run 4 electrolytic axial caps? Does it make a difference or is it a space saver?
    Yep the caps in a can is a space saver. Other than that there's no difference if using axial (or even radial) e-caps
      Thats what I thought, just wanted to confirm, Thanks!
        Wouldn't hurt a thing to up that first cap value to say 40uf to tighten up the bottom end in that thing.
          I'll add one to my parts order and give it try. Thanks for the info.
            I don't like can caps personally, I feel like they get too hot all stuffed into that little can filled with tar. I went through 8! Vibro Champs last year and every one needed a replacement $45 can cap. I did it for cosmetic reasons and to resist getting caught up in modifications. But I would prefer individuals if I were in a position where it could go either way.
