Chassis Hole Sizes
  • Chassis Hole Sizes
    Can anyone tell me what size holes are needed in the chassis for 6V6, 12AX7, and 6AV6 tube sockets. I have an opportunity to purchase a conduit knock out punch kit and the seller claims it can be used for tube chassis punch outs.
    I believe you need 7/8" and 1-1/8" diameter holes.
    Check out my signal generator for your iPhone or iPod Touch.
      Different brand/mounting styles for the same pin number require different sizes.
      For example:
      http://www.hoffmanamps.com/MyStore/p...R_ID=192143096
      -Mike
        Be careful there because conduit hole dimensions are different then what the actual conduit diameter is... measure first.
        Bruce
        Mission Amps
        Denver, CO. 80022
        www.missionamps.com
        303-955-2412
          What defaced said. Sometimes for Octal sockets you need 1" diam, sometimes 1&1/16", sometimes 1&1/8", and for noval sockets sometimes you need 7/8", sometimes 3/4".
          I've got a range of chassis punches I found in 2nd-hand tool shops (at different times). They make the neatest holes.
            Thanks for all the info guys! Bruce was right,that conduit sizes are different than what we use. So you can use the conduit punches.
            1/2" conduit size will give you a 7/8" hole
            3/4" conduit size will give you a 1-1/8" hole Thanks again, Rayme
