Speaker Wiring
  • Speaker Wiring
    Hey guys
    I have a speaker wiring query
    I'm building a 2x12 cab, using a WGS Reaper and a WGS Vintage 30, both are 16 ohms
    I'm wiring them in parallel (8 ohms), but I also want them wired so that I can use each speaker individually
    So I'm enquiring if my diagram is correct to achieve this, if not, could someone correct me?
    Regards
    Dave
    http://i39.photobucket.com/albums/e1...WiringPlan.jpg
    or is this one correct?
    http://i39.photobucket.com/albums/e1...ingplannew.jpg
    One jack should open and connect just the single 16 ohm, as does the other single. Then the dual speaker jack connects to both switch contacts connecting to both speakers in parallel.
    Now Trending: China has found a way to turn stupidity into money!
      I used 3 open switch mono jacks to achieve this and it worked a treat
      http://i39.photobucket.com/albums/e187/dayvo/Wiring.jpg
      Special thanks to Martin over at 18Watt.com for his help
      Dave
