That's harsh! (But probably true LOL)
Building Fender Frontman 212R
I call them insurance resistors myself. Not sure what the official term might be. PV often uses as many as sox grounds, and then some of them are tied together through 47 ohm resistors. But since the ground points at the jacks are also in contact with the chassis, those 47 ohmers are usually shorted across. but if the jack nut ever falls off, the resistor insures a ground reference.
Same here, that 10 ohm goes to a chassis connection, but so do the jack grounds in many cases. In some amps like a lot of recent marshalls, the whole thing is raised by a 10 ohm resistor from chassis in an attempt to beat ground loops.Education is what you're left with after you have forgotten what you have learned.
