Ive got a 330-0-330 pt out of a amoeg reverbrocket circa 66 and the ot which feed a pair of 6v6s.It uses ss diodes for rectification.I was gonna build a 5e3 deluxe .any other ideas? Thanks
ive got transformers! What shall i build?
No suggestions. What amp you would like is really up to you. I will say that with a SS rectifier that 330-0-330 PT is going to be wayyy too much voltage for a 5e3. Or any 6v6 amp for that matter."Take two placebos, works twice as well." Enzo
Plugging the numbers into Duncan PSU2 using a SS full wave rectifier and appropriate loads I get 440Vp to 450Vp. That's too high for 6V6's."Take two placebos, works twice as well." Enzo
Yea, but I'm old school. I know the current model 6V6's (or a similar but different tube marked "6V6") will take it. It's just silly high for that tube though."Take two placebos, works twice as well." Enzo
Both my blackface Fender Deluxes are putting out 430+ V on the plates and that's AFTER I plug into a bucking transformer that's bringing the AC down to 115!!!! Fender seems to have been pretty optimistic about the quality of 6V6 tubes, although at the same time they were cheap *sigh*
Several ways to reduce the B+ for real old 6V6 tubes. If the PT has a center tap, you can use a Zener diode.
https://taweber.powweb.com/store/vdump.htm
If there is no center tap on the PT, you could use a bridge rectifier and a copper cap (tube rectifier simulator) in series.
Weber Copper Cap Rectifiers
Yeah, why not the Reverbrocket? You could build a sort-of-5e3, but it won't have a classic 5e3 sound. A blackface Deluxe comes close to those specs, IIRC.
I'm into frankenstein builds, take the power amp of one build and combine it with the pre-amp of other amps. I want amps that don't sound like other amps out there, although with tubes that isn't hard to do even if you use the same circuit. I've really liked the flexibility having a two channel amp with a Fender and a Marshall style pre. I've done both on top of Fender and Marshall power amp style circuits. I don't build a lot. I think I've averaged one every 3 years now for the last 12 years. I really dig the creativity needed for found parts. Otherwise, just buy a kit.
Joe
