Can you guys show me some photos of your amp builds?
  • #76
    Originally posted by Tom Phillips View Post
    Result is:
    This photo is private.
    Oops! You don't have permission to view this photo
    And that was after I logged in.
    Sorry about that... i just updated all the permissions and it should be showing now.
    Sound Clips:
    Here are two short clips of my buddy playing a MIA strat playing through 2 amps simultaneously; the 6G15 Reverb Unit into the 5E3 Deluxe for the "wet" signal and a Dave Hunter 2-Stroke amp for the "clean" tone.
    https://app.box.com/s/vhajvuuuxptibqq23u67
    5E3
Name:	Screen Shot 2013-08-15 at 9.44.44 AM.png
ID:	829947Click image for larger version
Name:	Screen Shot 2013-08-15 at 9.44.51 AM.png
ID:	829948Click image for larger version
Name:	Screen Shot 2013-08-15 at 9.44.58 AM.png
ID:	829949Click image for larger version
Name:	Screen Shot 2013-08-15 at 9.45.04 AM.png
    6G15
Name:	Screen Shot 2013-08-15 at 9.45.20 AM.png
ID:	829952Click image for larger version
Name:	Screen Shot 2013-08-15 at 9.45.11 AM.png
    5F1
Name:	Screen Shot 2013-08-15 at 9.45.28 AM.png
ID:	829953Click image for larger version
Name:	Screen Shot 2013-08-15 at 9.45.33 AM.png
ID:	829954Click image for larger version
Name:	Screen Shot 2013-08-15 at 9.45.40 AM.png
    My Builds:
    5E3 Deluxe Build
    5F1 Champ Build
    6G15 Reverb Unit Build
    • #77
      Here's a few of the amps and cabinets I have built since 1997 / 98.
      Black Face Princeton Reverb variation
      Front
      Back
      4 x 6V6 amp
      102 Amp
      Front
      Back
      Ampeg SB-12 variation
      Front
      Back
      DIY Links
      Tolex Tutorial
      http://www.guitarkitbuilder.com/cont...lifier-cabinet
      Chassis:
      http://www.guitarkitbuilder.com/cont...lifier-chassis
      Turret board:
      http://www.guitarkitbuilder.com/cont...d-construction
      • #78
        Still need to add the reverb. A Champ with BF treble and bass controls but switches to Tweed with volume and tone controls, treble turns into the tone control.
        • #79
          Here's a couple. The first is a Hammond AO-35 conversion. The speaker is a P12N with a Jay Mitchell donut in front of it.
          The next is a preamp based on an Alembic F2B. I wanted to play with PCB/turret construction. I was still adding some things at this point. Never did get a final gut shot.
          • #80
            Sounds lovely mort
            • #81
              Heres a fun combo amp and extn cab I built last summer. Its based loosely on the t-bolt but with a few refinements. Switchable single/parallel V1 (wired on the input jack tip switches) for normal/boost, James TB stack, paraphase inverter (from the t-bolt) and 220R cathode resistor biasing 2 x 6P3Se with a Sovtek 5U4G. The OT is one of Webers. Goes into blues/rock mode real easily. The amps been gigged a few times and the cabs are starting to get a few dings but they are oil stained so the maintenance is easy.
              • #82
                some bytes of the above amp. Not up to my usual excellent standards, but it gives some idea of the raw sound
                • #83
                  Here's my Trainwreck build. I had some help from the guys on here with the MOV output transformer secondary protection idea to replace the diode string. I did a Star Grounding layout, and fused the power transformer.
                  • #84
                    Still no photo of the underside of the power-supply board, but here is a photo of the completed amp. At present, the amp has a variable boost (called 'Attitude') and a pair of master volumes (that I call a dual-stage master volume setup).
                    • #85
                      Here is a couple I put together
                      • #86
                        Damn, There's some nice work posted here lately!
                        "In theory, there is no difference between theory and practice. In practice there is."
                        - Yogi Berra
                        • #87
                          2xEL84, fixed bias, 2204 preamp. Waiting on a couple more output jacks (L11)
                          • #88
                            Looks really pretty! The 2204 preamp is going to just kick the snot out of those EL84s.. you may need to tweak the voltage swing of the PI, or build in some extra attenuation after the phase inverter / use smaller than normal grid leaks on the power tubes (or some other standard trick) to keep the bee-in-coke can tendency of the EL84s under control.. Looking forward to some clips.
                            • #89
                              Stormbringer, Just Curious how you get a 2204 preamp with only 2 ECC83s?
                              I only count 4 tubes, and 2 are EL84s?
                              T
                              ** I think I see another preamp tube hid near the input Jack?
                              Terry
                              • #90
                                Yes, I'll implement standard tricks. I've installed a 250k dual-pot MV in place of the PI grid leaks; I might try 500k instead (but this works nicely). There is also some signal attenuation at the end of the preamp; and 820R and 45k for Rb and Rk, respectively. Currently, the tail voltage is at ~69V; I might increase Rk to drop more voltage across Rk...
                                The NFB and Presence have me a bit irked. I have a separate thread in the 'debuggin your build' sub-forum.
                                Other than the Presence control, I have been impressed with the sound so far.
                                T
                                Yes, there is a 12AX7 right next to the input.
