Originally posted by TarheelTechinTraining
View Post
power transformer bad?
Originally posted by Chuck H View PostEDIT: Looking at the JTM600 circuit again, it doesn't look like a voltage doubler to me.?. It looks rather like a complicated cousin of the one I posted.Originally posted by EnzoI have a sign in my shop that says, "Never think up reasons not to check something."
Originally posted by TarheelTechinTraining View PostThanks again. I'm still concerned about the 545 b+.
Originally posted by g1 View PostOoops! You are correct. I saw caps and an oddly drawn bridge and was also thinking a doubler may be required. It's not a doubler in the jtm600 bias circuit, just a cap coupled bridge. They needed to isolate it via caps so they could use the same winding to make the low voltage supply for the preamp (+/-26V)."Take two placebos, works twice as well." Enzo
What Tom said. Voltages for the amp that PT came out of linger around 480Vp. You'll be using a very similar setup as far as the transformer knows. I'll mention again that I had a project where I blew up a few EL34's at 470Vp before trying the Ruby EL34B. The Ruby's are still going strong and accept occasional trips into heavy overdrive with no problems."Take two placebos, works twice as well." Enzo
Originally posted by TarheelTechinTraining View PostI'm gonna be using the 16ohm tap off the OT and wondered if the NFB should be hooked to the 8ohm or 16ohm tap?"Take two placebos, works twice as well." Enzo
Originally posted by TarheelTechinTraining View PostOK so I have it up and running. Using hi input and everything is well. Move over to Lo input and one of the power tubes starts red plating. How can I delete the Lo input? I never plan on using it anyway.
1) Verified the bias voltage at pin 5 of each poser tube. Please measure and post. Monitor that voltage when red plating starts if possible and report.
2) Move the position of the power tubes and determine if the red plating follows the tube or stays with the socket.
What was the final loaded B+ voltage?
What is your bias setting? (Current draw at idle)
Don't start the amp again with tubes plugged in.
The initial test for an amp should include firing it up with no tubes in and checking voltages on ALL the socket pins and power supply nodes from the rectifier on. If you don't know how to interpret the results, post them here.
Possibilities are numerous with a new build like this so I'll reserve speculating while we wait for more information."Take two placebos, works twice as well." Enzo
