Originally posted by mozz
View Post
Traynor YBA-1A lowering the plate voltage
Originally posted by mozz View PostIt (CCW)should put both the wipers right at ground so you should have no signal at all. Sure you have the pots common ends at ground?"I took a photo of my ohm meter... It didn't help." Enzo 8/20/22
Continuity on a meter usually refers to some low resistance, maybe less than 40R or less than 200R depending on meter.
On ohms scale, what is the reading from middle lugs to ground, with pot turned all the way down?Originally posted by EnzoI have a sign in my shop that says, "Never think up reasons not to check something."
I had to redo my wires as coming from the PPIMV not sure what happened , I used a wire similar to Gibson shielded wire like the have in there pickups only this stuff has a Teflon insulation on the center wire & i heat shrink tubing over it ,not sure what happened maybe the center wire touch the ground somewhere ... I redid the wires & it's working properly now ."UP here in the Canada we shoot things we don't understand"
