Amp Build: Ceriatone Kraken 50
  • #46
    Yes that would work about the same.
    120k // 56k would give you a 38.1818k
    but its a kludge.
    I didnt look thru the thread but what kind of speakers are you using?
    • #47
      but its a kludge.
      G12M-25s. I have another cab with G12H-75 Creambacks that I need to try too.
      • #48
        nice speakers, your build is excellent.
        • #49
          Originally posted by FourT6and2 View Post
          There should be more than two clips. This forum only lets you post 1 video per post, so here's links:
          33K: https://www.youtube.com/watch?v=izmQGKOERPE
          35K: https://www.youtube.com/watch?v=hSuZCKDQbDo
          39K: https://www.youtube.com/watch?v=v3Z5DMVvDG4
          47K: https://www.youtube.com/watch?v=-qtC8sVu-QA
          Thanks for the links!! I really like listening to how the builds sound as much as reading about the builds themselves. I will listen to all the clips again. What's your favorite, and why?
          • #50
            I listened to all the clips, and the one that sounded the best to me was the 35. So if you use a 36 that would probably be as good as it gets. The higher values seemed to produce a little lower wider sound. I actually liked it also, but it would not be as focused in a band setting for lead work.David
            • #51
              Yeah, the higher value slope resistors shift the tone stack's center frequency down. You can still get the same sound as other values. But you just need to adjust the EQ a bit. But the top and bottom ranges of all the EQ controls are different, while they will all overlap a bit in the middle. The clips are all with the EQ at 12:00. So a 33K can sound the same as 47K, for the most part. Just need to really adjust the tone controls.
