Hi All,
There was a great, and short, thread that is pretty old, about this topic, Tom had posted some instructions on a hard wired version of this mod. http://music-electronics-forum.com/t2205/ A couple of open questions came up when I started going through the details. Please excuse my poor drawing (done in MS Paint and not quite complete)
![Click image for larger version
On new builds the suggestions are fairly unanimous to use shielded wiring from the inputs to V1, and move the 68k grid stops right to the tube socket pin.
This cascading "mod" is to route the wire coming off the normal channel volume pot, after the 270k resistor, back to pin 7 (input) on the bright channel, and disconnect the wire coming from the input jack.
If I moved the grid stops to the pin on the tube, then should this wire go through the grid stop, or around it?
Is it OK only to disconnect one half the input for this tube, or do I need to shut off both inputs? I.e. would something horrible happen if the cascaded gain was turned "on", and someone put a jumper from the live input going to pin 7 to the other input jack pair going to pin 1?
I recall lots of bits and comments, e.g. Blankenship, talking about people who added gain stages and oscillated their amps to death (its was a comment he made about all repairs he does bringing the amps back to stock/factory). Since higher gain, is more likely to lead to unwanted oscillations, what can I do to reduce that chance? V2 has no grid stop on its input, would adding one there help to reduce this chance? I did plan on putting 5.6 or 6.8K grid stops on the output tubes, where the original-original schematic had none.
Thanks
Mike The Tinkerer
Thanks
Mike The Tinkerer
