push pull amp that uses a 260 0 260 HV transformers?
  • push pull amp that uses a 260 0 260 HV transformers?
    Hi All,
    An amp parts blog has a set of Heyboer transformers for sale for reasonable price. The PT has a 260-0-260 HV winding. Ive searched and searched but most push pull amp schematics ive seen use at least 300-0-300, most higher than that. Is there a classic (60's 70's) amp that uses HV winding this low v?
    Thanks
    Googling around seems like that transformer is common for Trainwreck Rocket builds.
      Cool, thanks G! Mind if I ask how did you phrase your search? I couldn't get anything.
        "Heyboer 260-0-260" found some threads talking about Rocket builds, which I didn't even know what that was, so then did "Heyboer Trainwreck Rocket."
          Thanks this is way cool. Always wanted to build one of the trainwreck clones. Its about to amplifier again!
          holiganbet betturkey
