Starting new kt120 UL project.
  • Starting new kt120 UL project.
    Hello. Get new toys thinking to start a new project. 4xKT 120 in UL mode . 650 V / 2300k load. Power supply plan:
    Click image for larger version  Name:	20200816_172600.jpg Views:	0 Size:	2.48 MB ID:	911230
    "If it measures good and sounds bad, it is bad. If it measures bad and sounds good, you are measuring the wrong things."
    A UF5408 does not have a high enough reverse blocking voltage for this. Worst case 470VRMS = 658V peak and the diode will have to block twice that = 1316V. You need to you two in series in each leg of the bridge and use say 1M parallel resistors to equalise the reverse voltage across them. That's total of 8 diodes and 8 resistors.
      Thanks Nick
        Looking forward to see how this develops. I have been intrigued with KT120 since they came out but never bought any to try. Amp should have plenty of kick I expect.
          Hello.
          May I use 1900k OT for a kt88 quartet in UL mode, supplied at 600V, please? Thanks
            May I use 1900k OT for a kt88 quartet in UL mode, supplied at 600V?
            KT88 datasheet recommends Zaa = 7k for a pair at Va = Vs = 560V with UL (40% taps).
            That results in Zaa = 3.5k for a quartet.
            Generally it is advisable to increase Zaa with higher Va.
            I think you could use your OT if you double speaker impedance.
              Dunno how accurate this online loadline tool is https://www.vtadiy.com/loadline-calc...or/#calculator
