Well, my head cab is just about ready for tolex. But I had a few questions.
1. I bought black metal corners to put on after the tolex. They came with half inch woodscrews. Should I drill the wholes in the Cabinet before applying the tolex? Should I drill at all or just go ahead and screw them into the tolex without having drilled.
2. Here are the feet I bought, http://www.mojomusicalsupply.com/ite...983&id=9000001 They did not come with any screws. What would you recommend as far as screws to secure the feet to the cab.
3. Same question for the feet as for the corners. Would you drill wholes prior to tolex, would you drill wholes after tolex, or would you just not drill period.
4. Any good tolex tutorial sites? I have found a couple that are pretty decent, but if you have any you recommend, that would be great!
Thanks
PS. I apply the tolex tommorow and I am scared as hell. The head cab came out great. So much better then I thought it would have, but I can still easily screw it up with a bad tolex job.
Thanks
