Lynn's jig
google
General EZ Pro Dovetail Jig
In my opinion, the box joint or finger joint is a superior joint for a cabinet. As you will need to cut more box joints than dove tails for the same width of board, you will ultimately end up with more glue surface area.
Dovetails are best used in drawers or cabinets where the joint is oriented vertically. On the amp cabinet, the joint is oriented horizontally and will not resist racking as effectively as a finger joint. Not that it probably matters all that much. Regardless, I use finger joints due to the inherent greater strength in this particular application.
help, I have setup the dovetail jig and I must have the bushing set to high as I cannot cut anything. Could someone shed some light! I maesured the half inch like the video says and set the jig and then when I go to cut nothing seems to work properly so before I burn out a bit I thought to come to this forum in hopes that someone can help me out!
Bill
