VOM 20023 or RCA RS199C
  • VOM 20023 or RCA RS199C
    Anyone ever converted one of these tube amps over for guitar/harp use? The Voice of Music uses 4-6V6s, a 12AX7, and a 5U4GB. The RCA is a pair of EL84's and something else I can't recall right now. I am a newb and know it, so suggestions are appreciated.
    can you post pictures of the amps.
      yep, i'll take some and post them. i'm away from the amps at the moment. Both have good iron.
        Here you go.
          They both look like 2 channel amps . You could put one fenderish preamp in front of the 4 6v6 amp but you would have to use 2 speakers all of the time .
          You could do the same thing with the el84 amp but find a preamp schematic that has a el84 in the power section . Check schematics heaven.com
          You gut them both out and start from scratch which is more fun and time consuming .
          baddog
            Thanks Baddog!
