I'm working on a Mojo 5F1 kit and I am going crazy with it. I have followed the Layout sheet that comes with it and wired the whole thing up. There are many detail omissions on it. When I turn it on and the tubes get going it make a loud steady hum. The tubes do light up but when I plug in a guitar chord there is absolutely no output. I have a major question concerning the AC chord. I have a separate ground for the green, I have the white going to the bottom lug of the fuse holder and the black going to bottom lug of the volume pot. Is this correct. The layout I have has colors for the wires of the PT only but not the AC Wire. The filament wires are shown as green as well. Please note that I have fixed the filament wires and they are nicely coiled.
Another 5F1 Newbie Here
Originally posted by stratluvr View Post...I have the white going to the bottom lug of the fuse holder and the black going to bottom lug of the volume pot. Is this correct...
Have a look here, in the middle of the page, power supply hookups. He also has tips on jack wiring that are very useful, and other reference items - its worth a look.
Common hookup info
I switched the AC leads and low and behold, the horrible hum went away. I was suspecting that from the beginning but didn't exactly know. Now I have to find out why the third Cap has no voltage and the first two have too much. I am finally starting to see a light at the end of this tunnel. Another question I have is that I noticed on the Layouts that bottom lug on the volume pot has an arrow pointing up. What exactly is this?
That is a stylized symbol for "switch". The black plastic item on the back of the volume pot is your on/off swicth. Incidentally, looking at your pictures, if that large orange cap next to the fuse holder is attached to either the hot or neutral lines, you should remove, it is not needed with a three-wire cord, and was possibly the source of the hum you experienced.
Regarding not getting DC at the third filter cap, check for ground on that cap, also check resistor to that cap.
