Hi,
Finally finished my 5E3 last night. spent a few h ours troubleshooting untill I found my guitar lead was faulty!!(Newbie error)
The Amp is working, only a small amount of hum.
BUT, Both of the normal inputs seem to be unaffected by either volume pot. I have checked all the pots and they all seem to still be functioning linearly to 1 Meg.
Bright Inputs for both channels working fine, I find a lose of tone if the "other" volume pot is turned past 3 O clock.
The amp is also VERY clean. Still rather loud but not dirt at all.
The amp circuit is stock standard, With the exception of the Gz34 rectifier and the pre-amp is 2x JJ Ecc83s, Power tubes are JJ6V6s. B+ 400V
Any suggestions would be greatly appreciated.
Also a silly question. Are the two volumes for inputs 1 and 2, or for Bright and Normal?
Im also trying to check my power. I came up with 19watts so guessing i'm wrong or going to cook something.
I have 24.0 volts dropped across my 250.0 Ohm, Which gave me 96mA. So do i half that current as there is two tubes? so 48mA then multiply that to my B+ to get power?? Sorry for all the question. This is all rather new to me!
I have attached some pictures.
Dan
Dan
