New 5e3 build, faint sound..
    Originally posted by Bruce / Mission Amps View Post
    Another common error is to swap the 100 ohm filament balance/ground reference resistors with one or more of the 100K resistors on the plates of the preamp tubes.
    I did that and you caught it from looking at the pictures I sent!
    When I fired the amp up for the first time, all the tubes lit up but no sound. There is a shielded wire from the volume pot to a preamp tube. I did not trim the shield good enough and one tiny wire was touching a lug on the tube socket. After I fixed that, glorious sound!
    Don't know if the Triode kit has the shielded wire, but if it does, check it.
      Jazz,
      I should have worn both pairs of glasses! - operator problem.
      Try Again:
      12ay7
      1-120 2-0 3-2 4-3ac 5-3ac 6-115 7-0 8-2 9-3ac
      12ax7
      1-150 2-0 3- 1 4 3ac 5-3ac 6-114 7-0 (am radio though) 8-0 9-3ac
      The 6v6 heater elements check out too.
      thanks!
        No sheilded, cloth pushback wire. Thanks though.
          Hey Jazz,
          Operator problem, added another pair of glasses...
          12ay7:
          12ax7:
          1-150 2-0 3-1 4-3ac 5-3ac 6-114 7-0(with am radio) 8-0 9-3ac
          The heater elements check out on the 6v6's as well (the other info on them should be accurate)
          Thanks!
            Originally posted by 01bcat View Post
            Hey Jazz,
            12ay7:
            12ax7:
            Thanks!
            Filaments are fine.
            Radio on lug 7 is bad...
            Check lug 8 of the 12AX7 with respect to ground... it should be at least 35vdc to 60vdc in order for the tube to even turn on.
            I suspect an error there... maybe too many glasses now though.
            Bruce
            Mission Amps
            Denver, CO. 80022
            www.missionamps.com
            303-955-2412
              Hey Bruce,
              I can't help the eyes much - but I will check it out - thanks...
                O voltage on pin 8, also none across the cap it is connected to... ?????
                  Its Alive!
                  Thanks for the help, I missed a connection under the board.
                  It is humming like crazy, but the tone is there, just need to clean up the wiring, maybe change some grounding as Zephyr suggested.
                  Zephyr- can you tell me the changes you made to the grounding?
                  Bruce, your comment led me right to it.. Thanks.
                    The hum could be another wiring error. Miswired grounds can hum but a bad hum is usually indicative of a bigger problem like a miswire or a cold solder joint.
                    Chuck
                      Chuck,
                      I am going to go over everything once more, an re-do the heater wiring.
                      My volume goes from nothing the really loud in like 1/100s of a turn, if I dime it (or $0.12 it in this case) it squeals.
                      Any suggestions on where to look for the cause there?
                        a volume pot lead contact to ground (due to rotation and not much room) will cause problems too
                        don't ask how I know this
                        • #27
                          It also sounds like an input jack could be wired wrong and or not grounded right.
                          Short lugs 2 and 7 of the first preamp tube right to ground with an alligator clip lead and see if that kills the noise.
                          Bruce
                          Mission Amps
                          Denver, CO. 80022
                          www.missionamps.com
                          303-955-2412
                          • #28
                            Thanks, I will do that. There is NO clean headroom either.
                            • #29
                              OK - Stupid question:
                              If I touch the leads dropping to the 68k resistors on the normal input jacks, it shows continuity with ground. The brite jack leads do not. Normal?
                              Thanks.
                              • #30
                                No... the switching jacks should have the two resistors grounded at the input jack end.
                                I think that point should read about 32K-36K range on both pairs of resistors with nothing plugged into the jacks.
                                Bruce
                                Mission Amps
                                Denver, CO. 80022
                                www.missionamps.com
                                303-955-2412
