Origianl Jenson P12R Straight/Seamed Cone ?
  • Origianl Jenson P12R Straight/Seamed Cone ?
    I found a couple of original early 60's P12R's.. Ex Hammond Pull
    Trouble is the are not seamed cones as the original.. is the is a major issue.
    Thanks
    Gibby
    1959 Deluxe
    P12R
    I'm hearing the Deluxe actually came with a Straight cone from Fender.
    Is this true ??
    Gibby
      Early models came with a straight one piece cone, late '50 versions with a straight seam ribbed cone, early '60 models with a curved seam ribbed cone.
        P12R
        My 59 original cone was seamed, this pair of dated 63 ex Hammond Pull
        are Straight cone.
        I'll bang one in tonight, I'm looking for a clean tone at low volume and hopefully some nice early crunch at medium vol. as per Neil Young.
        Thanks
        Gibby
          this pair of dated 63 ex Hammond Pull are Straight cone.
          Hammond used different models, usually with a combination of straight and ribbed cones in the same enclosure.
          As you already know, a P12R won't last very long in a 5E3, you should consider either a P12Q, a P12P (my fave in this amp) or a P12N.
          Neil uses C12N's driven by 6L6's.
            P12R
            I only use the amp in my small home studio for practice and recording.
            The original P12R must of had an easy life to last so long..
            Soon as I introduced it to my Les Paul with a P90 and Fire Bird in the trunk it was history.
            It was awesome just before it died though
            Thanks for the Neil info, I heard he used the Weber for a while too.
            Gibby
