Here's a few traces. These are with all the tubes in except V3. First is the amp output. Next is V4 pin 1 and next is V4 pin 6. I'm still hearing a relatively small amount of hum in the headphones from the recording output even though I lifted the the .002 and .047 caps to isolate the recording circuit from the V4B grid. This is likely from the +15 supply at "H", but the problem at V4 is more significant. I don't know if the hum at V4 and the hum at "H" are manifestations of the same issue or whether they are separate issues.
Mesa Boogie F-30 Hum Problem After Repair
Originally posted by Helmholtz View PostPlease scope the bias voltage at point F using AC coupling.
Your scope pic shows a significant 60Hz ripple on the bias supply and assumingly on the PI cathodes as well.
I don't have a reference, but 0.2Vpp doesn't look right to me.
Does the 1000µ cap measure good (capacitance and ESR) and is it mounted with correct polarity (positive to ground)?
A new cap isn't always a good cap.- Own Opinions Only -
- Likes 2
Originally posted by Helmholtz View PostYour scope pic shows a significant 60Hz ripple on the bias supply and assumingly on the PI cathodes as well.
Something I noticed is that I'm only measuring 2V at "E" while the drawing indicates it should be 3V.The resistor is exactly 15K out of circuit. In any case, probably not relevant to my main issue.
Bob. Please tell me that the reason for the scope trace shown for the plate at V4B (last image post 122) and the scope trace shown for point F bias supply (post 124) are identical is an accident. At 129 posts in I would hate to think you're f#&!ng with us."Take two placebos, works twice as well." Enzo
- Likes 1
Originally posted by Chuck H View PostBob. Please tell me that the reason for the scope trace shown for the plate at V4B (last image post 122) and the scope trace shown for point F bias supply (post 124) are identical is an accident. At 129 posts in I would hate to think you're f#&!ng with us.
Originally posted by Helmholtz View PostNow that's a lot less bias ripple."Take two placebos, works twice as well." Enzo
Originally posted by bobloblaws View PostSomething I noticed is that I'm only measuring 2V at "E" while the drawing indicates it should be 3V.The resistor is exactly 15K out of circuit. In any case, probably not relevant to my main issue.
- Likes 1
Originally posted by Chuck H View PostDoes that mean the ripple seen there probably isn't the problem? I've never had to quantify how much bias ripple is a problem so I don't know.
Also both bias and PI tail ripple are common mode signals and should not appear at the output - if PI and power tubes are balanced.
- Likes 1
