Viper20A IC in XP510i Samson
  • Viper20A IC in XP510i Samson
    This Viper20A chip (DIP) in the SMPS is obsolete. Has anyone used Viper53EDIP-E as a sub.? schematic and data sheets attached.
    Power light is pulsing and supply making clicking noise. When I hit the Viper chip with freeze spray it starts working normally and power amp works.
    Another question about this mixer, main fan is very loud, it's a 12V fan running at 9V, I guess the fan is just bad?
    It looks to me like the two chips have different pinouts.
      FWIW: I did find a Dalbani "pull" on eBay. I've had good luck with them. They are original parts and tested. Not sure what it would cost to ship to Canada.
      https://www.ebay.com/itm/12120131713...Bk9SR-C6l6DEZA
        Well then, so much for 'substitute' suggestions from digikey.
          I saw the Digikey suggestion, too. I'd have to look again, but I think the SMD versions are different pinouts than the through hole versions. Maybe that's the confusion. I saw that on the through hole versions one had supply on pin 2 and the other on 7 (among other discrepancies).
            The SMD doesn't match either.
            The Dalbani part would be pretty much same for shipping as part price, so I will check if available from Samson dist. first.
              IC no longer available via Samson, same for fan.
              Audiolabga has the IC, hopefully they will have a fan that fits as well.
              casibom betturkey
