A downloadable schematic is available here: https://elektrotanya.com/princeton_s.../download.html
Issue: Amplifier has a sympathetic distorted tone accompanying the primary clean or drive tone. It sounds identical to a fuzz channel bleeding into the clean channel. However, I don't believe it is channel bleed through in the traditional sense, as it presents on the so-called "drive" channel, as well, and is not affected by manipulating the knobs on the secondary, "off" channel. It also is not related to the speakers, as the problem persists using any of my external cabs. The problem DOES NOT present through the headphone jack, so my assumption is that it is in the output stage of the amp and not from the preamp or anything upstream. No obvious problem components on the board, though I replaced the power filtering capacitors for good measure. Golden-brown board coloration around the Zenner diodes (CR19/20 on the schematic) suggest they get pretty warm, but they tested okay. I've desoldered a leg on most of the electrolytic capacitors so I could check them with my meter - all were within spec.
Any advice for where I go next? Start checking resistors? Swapping IC chips? Could it be the IC power amplifier chips, themselves? I will note that this is a stereo amp and the issue is present in both L/R channels, though maybe to a lesser degree in one than the other. Thank you in advance for any guidance.
Background: I dabble in amplifier repair (mixed results, but more wins than losses), but typically tube amplifiers, and usually the obvious culprit components. Solid state has me stumped. I've completed a handful of mods, a successful "Champ" build, and saved a few lowish-value amps from the scrap heap. I've also inadvertently hastened a few amp's journey to the scrap heap. I have an iron, a multimeter, and a capacitance-dissipating safety screwdriver.
