Speaker cab x-over relay function?
  • Speaker cab x-over relay function?
    i have a carvin 2x10 wedge cab with a horn.....the horn was cutting out intermittently. i pulled the crossover and i think i've determined the relay (12A/24v version of this: http://www.nteinc.com/relay_web/pdf/R46.pdf ) is intermittent. i'm not sure its function, but i think it might be protecting the horn from voltage surges...? i don't have a schematic.
    i've soldered a jumper wire across a couple of the relay lugs....everything seems to be working fine now...no intermittent horn operation. is it harmful to the amp to leave it like this? i'm hunting down a replacement tomorrow, but in the event i can't find one quickly, i'm wondering of there's a risk in just leaving the bad relay bypassed.
    thanks for your help!
    hello?
      COntact Carvin and ask for the technical information on this enclosure including crossover schematic.
      casinolevant levant casino
