Ampeg B12XT Motorboating on Intensity
  • Ampeg B12XT Motorboating on Intensity
    Guys,
    I have a late '60s Ampeg B12XT, which I have been repairing for a friend.
    I have replaced caps and brought the voltages all down within about 10VDC of where they are spec'd. (with 125 at the wall)
    I also installed a new tremolo unit VM1-R from Fliptops.
    The amp is quite, and all effects work...it sounds great except:
    The echo control adds a motorboating effect. (Put.Put.Put...ect)
    As you turn up the intensity control it gets louder.
    Is this the bypass cap on the verb drive/receive?
    What causes this?
    With the Echo (reverb) turned off, the amp plays and sounds great. Tremolo sounds great, when no reverb is being added. All effects work well, you just have to ignore the motorboating on the echo control.
    Caps on Verb Circuit
    Okay fine....it was the caps on the verb circuit....not sure which one, I changed 'em all...
    Not to mention the bozo before me had installed a completely wrong cap as the bypass cap on the 12AX7 under question
    casinolevant levant casino
