Nice call Enzo that was a pretty swift assumption. Power supply should be the same.
Peavey VYPYR 15
Thank you, thank you, I'll put the gold medal in the case with the others.
Unfortunately the waitress at the local diner doesn;t know about this, so I still will get her thumb in my soup.Education is what you're left with after you have forgotten what you have learned.
Originally posted by Enzo View PostSchematics for Peavey products are usually easiest to find at customer service at Peavey.
NO lights means either the logic has no power supply, or the logic has failed. Customer serviec can tell you the reinitialization procedure. ther are four buttons and you hold 1 and 4 or some combination while you power up. There are only a few combinations, so if it is not 1-4 or 1-3, keep trying combinations. or ask them. it might be all you need.
Footswitch for peavey vypyr 15
Hello,
I bought this peavey 15W some time ago and I w'd like to make a footswitch to switch between the different presets (I know this amp doesn't have a footswitch input), does somebody know if it's possible to modify or to add a circuit and "make" an input?
You could have the same problem like I had. Faulty 2040 chip which killed the 18-0-18 bridge rectifier diodes thus no power to the DSP board. Check the diodes D3 D4 D5 and D6. If they are faulty the DSP board won't get the power supply. Also get a new TDA2040 or TDA2050 chip. Simple fix.
Originally posted by s1ms View PostYou could have the same problem like I had. Faulty 2040 chip which killed the 18-0-18 bridge rectifier diodes thus no power to the DSP board. Check the diodes D3 D4 D5 and D6. If they are faulty the DSP board won't get the power supply. Also get a new TDA2040 or TDA2050 chip. Simple fix.
I just bought a Vypyr15 at a flea market and there is no input jack or board. I looked at the schematics Enzo supplied earlier in this thread and did not see anything for the input board itself.
What circuitry is missing? An op amp as a preamp? If I had a schematic I could build a replacement. I see a signal input, +/- 15VDC, and audio input. Do I need to ground the Input_Jack signal to get it to work? It doesn't seem to make any difference. I only get a faint buzz at full volume when I touch the pin 6 of P5 with my finger. Also, the pins on the six pin ribbon cable seem to be inverted based on voltage readings.
Any help is appreciated. I could not find schematics on the Peavey site.
