Heater voltage too low on Fender Showman
  • Heater voltage too low on Fender Showman
    Hello all- started working on a Fender Showman but didn't get a whole lot of time with it today. The amp is making no sound- the B+ and plate voltages all appear to be fine, but I was only getting 2.8vAC on the heaters. Also the power indicator lamp isn't working- didn't have time to try a new one but I'm assuming maybe the voltage is too low for this as well.
    Any thoughts on this? Is the PT bad?
    I appreciate any help- thanks.
    Did you measure the winding from end to end or from one end to ground? I would think the pilot would light dimly at too low a voltage so the lamp is probably bad. Just for kicks try removing the lamp and retest. If it's still too low unsolder the winding and re measure just to be sure.
    Chuck
      I measured from one end to ground. I'll give your suggestion a try tomorrow. Thanks for the reply.
        It should be measured from end to end. As should any AC voltages. DC is measured to ground.
        Even at that 2.8 volts seems low. But at such a low voltage it could be meter error.
        Chuck
          Ok thanks. My mistake- hopefully I'll get it going tomorrow. Might be getting back to you.
