Hi. I have an early 70's ampeg v2. When I got it, it was in pretty rough shape, Other than that it has had a recent cap job. I have since then replaced all of the other cap in the amp, and most of the large resistors. The only mods that I know of are:
Master Volume
Adjustable bias
El34 power section (w/ proper screen resistors)
12ax7 throughout the preamp minus the reverb
I'm getting a red plate, and a glowing grid on the inside tube only. It only happens when I am putting a signal through the amp and it is turned all the way up. The bias is set very low as well.
The bias voltage stays constant, so i don't think that is it.
It does this with 6l6's as well
Plate voltage stays fairly constant
Screen voltage jumps all over the place.
the redplate follows the socket, not the tube.
I checked the AC voltage going into the control grids of the power tubes. Sure enough, the problem tube is getting at least 20 volts more with the same signal going through. I checked the plates on the PI. same thing.
I've checked every resistor value, pulled out one lead, checked again. The caps are brand new. stock values all around. I put a 12au7, which is what the design calls for. same thing.
The PI should put an identical signal into each side of the power tubes. right?
this is my power amp: http://www.schematicheaven.com/ampegamps/v2powamp.pdf
I am at a loss. Any help will be appreciated.
garrett
Master Volume
Adjustable bias
garrett
