Dual Marshall Footswitch
  • Dual Marshall Footswitch
    I have a Marshall MG100DFX, amp works great even though the fan is a little noisy.
    Does anyone have a wiring diagram for the Clean/Overdrive,OD1/OD2 switch. There is a blue wire loose with the Red wire connecting to the Resistor for the L.E.D.
    I cannot find a diagram anywhere and I am unable to use the pedal. Thanks,Van
    [B][I][COLOR="DarkOrange"][FONT="Comic Sans MS"]:thumbsup:[/FONT][/COLOR][/I][/B]
    mg100dfx.pdf
      Thank you for the Schematics, maybe I was not clear on my post, I actually need the wiring for the foot swith itself. I looked through the Schematics and did not see them. Thanks, Van
        Marshall FtSw
        There is not a schematic for the footswitch itself.
        There are hints on the one provided.
        Page 1, top left is the switching circuit.
        Page 3, bottom left is the footswitch jack.
        Pin #1 (FS C) is high +5Vdc
        Pin #2 (FS B) Is high +5Vdc
        Pin # 4 & 5 are ground.
        Insert the footswitch plug into the amp and trace out where each wire goes.
        Make a drawing, scan it & post it here.
          vanink ..how's it goin with the footswitch problem..i too need the knowledge
