I've done my share of solder-in mods to tube amps over the last couple years. I've learned my way around them fairly well and am abreast of all the safety measures I should take before embarking on my journey to do my first recap of a Rauland-Borg 2010 PA amp that I've converted over for guitar.
Already I have switched out the old Ampenol mic input for a 1/4 inch jack, and have added a 1/4-inch 8 ohm speaker out. Right now, the amp has demonstrated great potential to sound good, but has hum clearly indicative of bad filter caps.
This amp is a little 10-watt amp driven by a single 6L6, has a 12AX7 in the preamp side and a 6CA4 rectifier. It sports a mic volume (now main guitar volume), a phono volume for an RCA input and a tone control.
I have removed the wiring to the RCA inputs to make room for the mini caps I will add. I am going to use Sprague atom caps of the correct capacitance and voltage. Right now the amp has an old Mallory FP style can on top. I will leave it there strictly for cosmetics but will run all the respective positive connections to the positive ends of mini caps.
My question, though, concerns where to ground the mini caps. Can I use what I suspect to be a grounding tab off the original FP can? I have attached a picture of the inside of this amp.
Please note that the wiring you see going from the RCA inputs to the pot in the center no longer exist. I have cleared them out of the way as a place to put the mini caps.
It is also important to note that I will be replacing coupling caps, adding a three-wire grounded cord and new resistors as well. In the end, I will probably even replace the pots.
Any advice you can give me on the proper grounding location for the new capacitors would be appreciated. As I said, this is my first project. I have no money in this amp so it seems like a good launching point.
Thanks so much!
-Adam
Thanks so much!
-Adam
