Marshall Mosfet Lead Output Stage Problem
  • #31
    i'm back with this amp with no success
    i'm gonna attach this amp to a 8 ohm load.
    I will post some voltages now without the transistors connected. to avoid more problems. When i fired the amp up i did it for about 8 seconds or less when the buzzing started so i inmediatly stopped using it
    the mosfets don't seem to be shorted . but i have to test them.
    Hearing Is Believing
    • #32
      That 8 second delay probably means they are either over biased or oscillating, either case overheating them very quickly.
      Until you have it fully fixed use a series lamp limiter.
      Rising brightness shows rising consumption.
