I just bought my Peavey classic 50/50 off of Ebay and did a complete retube with JJ's. thought Id test it out using my line 6 Pod XT, and after about 30 minutes blew the main fuse. is it possiable that I had the Pod turned up to much causing an over load to the amp? or is there another issue?
Also blew my main fuse in my Peavey Classic 50/50
New power tubes are most likely to fail early! You have a bad tube in the bunch that needs replacement from your vendor. jj maybe? It is common!sigpicCharlieP
(2)Peavey VK 112 2008
Fender SuperSonic 60W 112 2010, 5E3 Build Mojotone
Met. Red LP Gibson Robot 2008 Tronical Tuners
Faded Cherry LP Gibson 2007
Fender Strat HSS LSR S1 2008 Pearl
Fend FSR Telebot Dlx Candy App 2011 Tronical Tuners
Gretsch G5120 2007 Black
I just found that I blew a tube in the exact place there was a blown tube when I recived the amp. the guy claims he did not have any problems with the amp and never replaced any tubes. I find that very hard to believe since i recieved it with a blown tube.
Yeah, But if the screen resistor is open then the tube won't pass any current. How can a tube fail and take the fuse with it if it's not passing current?
There is something wrong with that socket though. Perhaps a carbon track is burned into it from a previous failure. The socket pins could be dirty, loose or have a cold solder joint and the tube in that socket is losing bias voltage at the grid pin. This is the kind of thing to look for. Something is making the tube in that socket draw excessive current.
Chuck"Take two placebos, works twice as well." Enzo
