I'm looking for some advice on getting rid of some excess noise.
The amp:
I'm having a bit of fun with an old solid state 60 watt general purpose type amp. It has a single ic in the preamp followed by a handful of discrete transistors in what I would think to be the "phase inversion" section of a tube amp followed by two tanky transistors which make up the power amp. If memory serves me correctly the ic runs at about 27 volts.
The problem:
When playing notes there is this subtle fuzz in the background. It is a noise similar to a snare buzz. It gets louder and quieter as you adjust the master volume accordingly, so its most likely in the preamp section. But as you play louder//softer the noise stays at a constant volume, until the note is very quite, then the noise is non-existent. The noise gets higher if the note your playing is higher and visa versa. The sound comes through with different different guitars//bases.
Im just looking for a push in the right direction, could it be something as simple as a noisy capacitor or resistor, or should I introduce more power supply filtering, or is the noise inherent in the layout or ic itself?
cheers.
The amp:
The problem:
cheers.
