Here's an interesting problem. I built a little drop-in FX loop unit for a Fender Blues Jr based on what was in the Blues Deluxe: a TL072-buffered serial loop that is bypassed when nothing is in the return jack. Here's the relevant part of the Blues Deluxe schem, which I duplicated in my build:
![Click image for larger version
It's well balanced and quiet except for one problem. When the amp is first turned on, it's fine, with the fx loop connected to a patch from in to out it's also fine, however when I then unplug everything from the loop it gets this faint background squealing noise- like a parasitic oscillation- that won't go away unless I power down the amp completely (to drain the +/-15V supply, presumably). Moving the FX loop around changes the pitch of the squeal. The two leads to the unit are both shielded - a double core lead for the send and return with the shield as the loop's ground connection and a 2nd lead with the core to the +15V rail and the shielding to the -15V.
Why would it only have this problem once something is plugged in and then unplugged? I have two identical units in two amps which are both doing the same thing so it's not a faulty switch in the return jack. I've tried moving both the 15V and send/return lines around while the squeal is going but it doesn't really go away- it just changes pitch. If I plug a patch cable in, it goes away but immediately comes back when unplugged again. It's almost as if part of the TL072 is not turning off...?
