FX loop buzz only when unplugged again
  • FX loop buzz only when unplugged again
    Here's an interesting problem. I built a little drop-in FX loop unit for a Fender Blues Jr based on what was in the Blues Deluxe: a TL072-buffered serial loop that is bypassed when nothing is in the return jack. Here's the relevant part of the Blues Deluxe schem, which I duplicated in my build:
    It's well balanced and quiet except for one problem. When the amp is first turned on, it's fine, with the fx loop connected to a patch from in to out it's also fine, however when I then unplug everything from the loop it gets this faint background squealing noise- like a parasitic oscillation- that won't go away unless I power down the amp completely (to drain the +/-15V supply, presumably). Moving the FX loop around changes the pitch of the squeal. The two leads to the unit are both shielded - a double core lead for the send and return with the shield as the loop's ground connection and a 2nd lead with the core to the +15V rail and the shielding to the -15V.
    Why would it only have this problem once something is plugged in and then unplugged? I have two identical units in two amps which are both doing the same thing so it's not a faulty switch in the return jack. I've tried moving both the 15V and send/return lines around while the squeal is going but it doesn't really go away- it just changes pitch. If I plug a patch cable in, it goes away but immediately comes back when unplugged again. It's almost as if part of the TL072 is not turning off...?
    Hi,
    I assume you have supplied the small drop-in unit using the amp's internal +/- 15 V rails...if so, I suggest you to throw in two .1 uF "poly" or ceramic decoupling capacitors, one between pin 4 (-V) and ground, the other between pin 8 (+V) and ground.
    Another thing I would do (only as an improvement, it has nothing to do with your problem) is to use an NE5532, because of its lower NF. It draws slightly more current than a 072, but in this case this is not an issue.
    Hope this helps
    Best regards
    Bob
      I don't get it. From the schematic, it looks as if the op-amp's feedback loop is broken by the jack switches. That could certainly make it squeal when the plug was removed, if you wired the jack socket wrong or used a jack with a different switching scheme to the OEM part.
        Yeah, that's my suspicion now. I'm 99% sure the switching scheme is the same but I'm wondering if I didn't stuff up the wiring somewhere. I tried Bob's suggestion of the 0.1uf's to ground on both sides of the 15V but it didn't make a difference. I was checking other parts of the circuit for AC when I noticed that connecting the jack side of the 10k resistor to ground with a 0.1u cap rid got rid of the squeal, but it *didn't* get rid of the signal when the send + return were jumpered with a patch cable. If pin 2 is the tip of the return jack connected to the 10k, the cap to ground should bleed off the whole 400Hz test signal I was using.
        Too late for today, but I'll give it a good look tomorrow to see if something isn't hooked up right.
          Well, it turns out when I cleaned up the speckly schematic scan from the Blues Deluxe, I missed a connection. The feedback loop on the 'B' (recovery) side of the TL072 should NOT be broken when unplugged. I jumpered pin 6 and 9 on the output jack and that cleared it up. Works great now, although there's just the slightest bit of insertion loss. I might reduce the 1M on the voltage divider of the input end to see if I can balance it out a bit more.
          Also, would the 47pF cap on the output be there to cancel out some treble? The loop seems to lack a bit of sparkle that is there otherwise. Not sure if that's the issue or the 1M input resistor needs a treble bleed cap with a series resistor? Or maybe I'm just imagining things...
            Yep, dropping the 1M to 660k seemed to get things to unity. 500k was too much. Not sure if the treble loss is still there or not yet.
