Vox VT 50
  • Vox VT 50
    no schematic so far.
    speaker makes mild hiss.. seems normal.
    power light comes on but no other lights on the panel.
    so factory reset impossible.
    about all I could do was check for continuity from the jack to the board it's on.. it all seems ok there. I get cont. and res. appropriate.
    I pulled the control panel pcb off and the big pcb.. nothing scorched, nothing hanging out.. etc.
    I cleaned lubed the pots... cleaned switches.. cleaned the boards.
    and stared at it a while.
    check the larger PCB components - resistors and capacitors - for possible broken leads. give em a gentle push and see if anything is amiss.
      thanks.. will do. seemed ok but I didn't really check thoroughly!
        If the only light that is coming on is the power, than you have a display board problem.
        It is a modeling amp.
        Meaning there is a microcontroller in there that lights the lights.
        And processes the signal, & does the modeling &....
        If the micro is not coming up, the amp is dead in the water.
        (Isn't the latest & greatest of new technologies just wonderful.)
        Try to find the board & look for any voltage regulators.
        There may be a 5 volt & a 3.3 volt.
        They must be working.
