This is a Fender Stage 112 se (1992)
Ok, so a buddy of mine asks if I can take a look at his amp because it's making a buzzing noise. I bring it in, plug in my guitar, it sounds ok. I crank up the volume to about 3 and it sounds good but low and high notes give a crackle and pop when played. After about five minutes of playing with tones and volume and striking notes on the guitar, it starts to make a rythemic pop, pop, pop, and it didn't change when I disconnected the guitar or turned all pots to "0". So I pulled it appart to take a look. Someone has been in here before. The first obvious things I found were CR28 had been replaced at one time and also Q2. However, when they were replaced, the master solderer used too much heat, burned the board and thus, removed the pads from the solder runs. So he/she brilliantly soldered a "jumper" between one leg on the top of the board @ CR28 to one leg on the bottom of the board @ Q2. I was glad to see the jumper was at least insulated. Because this was something goofy, I checked CR28, found it was "OL" one direction with continuity the other as a diode should be. No problem. So I cleaned up the solder on both sides of the board associated with both components, re routed the "jumper" to be completly on the bottom of the board, put it all back together again and turned it on. Instantly, I got that pop, pop, pop, pop. Nothing plugged into it, all controls at "0". I manipulated the controls, plugged an instrument into it, and nothing changed. The pop, pop, pop continued. I unplugged the instrument, turned it off, pulled it all appart again and just the control portion sitting on the bench plugged it back in, turned it on. The pop, pop, pop, was still there, so I went for my DVM but before I could probe any test points the fuse blew and the amp went dead. Sooooo, now what???? Any help would be greatly appreciated! I have also looked at all the solder joints to all the other components on the board. they are all attached and soldered, not cracked or broken. Also, replacing the fuse does no good. I've blown three now and can not check power levels at IC's without the board being powered. So I'm stuck.
