This amp had a broken 15 amp breaker. After it was replaced there is now no power. I checked C25 and 26 for shorts and they seem ok. I measure AC coming in to all the tab points on the primary of the PT and that checks out fine. So I disconnected the secondary J30 and J 31 and applied AC and on J31 between each of the winds I get nothing, mVs, but when measuring to ground I get 65vac.
I would think I should have some voltages between the windings.
,,, is this obvious or not that the PT is a goner?
