PK then, if it really needs to bias hotter, then explore the bias transistor and surrounding resistors. You may have to alter a resistor value.
Output transistors sockets SWR SM-400
Originally posted by slawkowski View Postunfortunately I do have sm-400, years back I had to rebuilt power supply in this amp
which is bad design from factory, this voltage dropping resistors are overheating
surrounding diodes and caps, and indeed this amp should be fan cooled,
Originally posted by slawkowski View Postnow my sm-400 (which is the PITA to work on it) has dc offset to high on one side and needs service again
slaw
Mark
Originally posted by Enzo View PostPK then, if it really needs to bias hotter, then explore the bias transistor and surrounding resistors. You may have to alter a resistor value.
Mark
Mark
Originally posted by MarkusBass View PostThe amp that I have has 7 mV on one side and 30 mV on the other. I think that this is caused by the differential input stage (not matched transistors). What offset do you have?
Mark
dc offset on one side 190mV and 42mV on other
I'm going to order bunch of MPSA56 and match them for hfe
