Hi all. Some of the older Traces - after the UV tube era though - have an electroluminescent front panel which runs on a HT supply limited to 7mA. The current is limited on a separate little board. A triac in the supply line is controlled by the CA3059, which is described as a zero-voltage switch - it's in a 14-pin DIL package. Datasheet attached. It is obsolete. Can anyone help me with an equivalent?
Thanks in advance.
CA3059 datasheet.pdf
Thanks in advance.
