Hi guys,
I'm brand new to this forum.
I've been looking through the other forums and found that I'm not the only one with this problem...
A friend gave me his Peavey Special 212 Trans Tube amp. When I turn it on (no guitar attached) there is a loud hum. The speaker cones push in and stay there. I've measured 7 VDC across the speaker wires. I also read about 17 VAC. I don't think the DC voltage is normal based on what I've been reading here. Is the AC voltage normal? I've tried resoldering the filter caps (which looked fine). I want to check the output transistors but there appear to be four of them? also not sure how to tell if they are bad. I sent an email to Peavey requesting a schematic so hopefully I'll get that soon. Another side note is it seems that this amp may have been stored in a damp environment for some time. Does this effect what I should be looking for? Any help would be appreciated. Thanks.
