peavey-heritage-vtx.pdf
Have this amp.. came to me with a bad distortion at all settings. Opened it up and found R3 (100 ohm 5 watt) open. Replaced it - no change. Replaced the 2 6465 transistors (Q9 and Q7) on a whim.... no change.
I am only getting 108 volts to pins 1 and 8 on the power tubes. I am getting 522vdc at 3 and 4.
I'm thinking now that it could be the transistors Q6 and Q8, but I do not know how to effectively test these and of course I am not sure these will do the trick anyways.
Any help would be much appreciated.
