COnsider where you have the scope trigger set. If your waveform keeps swapping phase, perhaps the trigger is set too close to zero. Try turning the trigger control. You don;t need an extrenal trigger, your scope triggers off the waveform perfectly well.
Digital and analog scopes can both have unstable displays, and they can both be rock steady. It is more about what they are connected to and how they are adjusted.
Plug your phone test signal into an amplifier and listen to it. Does the tone sound rock steady? Or can you hear the occasional shift or glitch? I don;t have such a phone, but I could belueve that while the phone is doing this app, it might also be doing other tasks, and those interruptions might cause little changes. AFter all, the app is not lab gear.
