Hi. Have a Marshall Class5 five watt tube combo and there was a resistor burned open. (R5..1K). Replaced it and checked tube which didn't test good so I ordered a new one and installed. Also installed a new fuse
(125mA) plugged in an external speaker and fired it up....Fuse blew. Had a 6BQ5 from a 1970's traynor so I replaced the fuse, plugged in a guitar and tried it again. Amp worked but after about 15 minutes I noticed that it was hotter than normal espically around the output tube. When I touched the tube it almost burnt the hands off me....way too hot....but the fuse did not blow. Reinstalled the EL84 tube again and as soon as I flicked the switch the fuse blew. Cheked the tube in the tester and it checked fine. Noticed that the insulating tape that is wrapped around the output transformer looks like it may have overheated....maybe??? Did a resistance check on the speaker side....low...a couple of ohms....checked the tube side and got around 97 ohms. Checked a data sheet on line and according to the specs the resistance should be around 5200 ohms for a class A design...Anybody have a rough idea of what the resistance should be reading??? I don't have a spare transformer to sub to check for sure......I will gladly order the transformer but want to make sure that it is defective....
Thanks,
Bernie
Thanks,
Bernie
