Hello,
I recently purchased a Fender Twin Silverface with the Ultra Linear taps. The condition wasn´t so good and the price was right so I was looking forward to doing some repairs and getting it back in order.
While sorting out some of the hum issues I was tightening and straightening out the filament wires. Unfortunately, I turned on the amp before checking if any of the pins on the 6L6 were touching. When I turned on the amp, I heard a loud sizzle then hurriedly turned the power off. It appears that pin 2 and pin 3 on one of the 6L6 were touching due to the length of wire coming out of pin 2. My straightening the wires had pulled the pins together to make enough connection.
The result is that the amp makes only wild oscillations-- I would thereby assume the OT is ok as it still makes a sound. The HT voltage has stayed roughly the same (470VDC) while the filament voltage is sagging. When unloaded, I am getting 6.3VAC while with the full complement of tubes in the voltage droops down to 5.6VAC. I believe I have ruined the power transformer in some way but I wonder if it is still salvageable by removing the filament wiring and installing a new 6A (4x6L6 + 6x12AX7etc = 5.4A) filament transformer. Am I courting serious disaster by doing this? Or should I simply try to replace the power transformer first (although there is no easy aftermarket alternative.)
Thank you for any help with this.
Bill
Bill
