Gentlemen, (and ladies, if any) I have two problems. First I cannot post pictures to this site since I got my new laptop running Windows 8. So I will have to try and explain as best I can.
I recently got a Webster 166-1 amp. This used to have two inputs, one for a phono and one for a mic (karaoke?). It has had a 1/4" jack installed for guitar running through the phono volume. Someone has recapped it and there is absolutely no hum. It just doesn't play very loud. I don't play real loud, but I want it to work correctly. My silverface Champ or Garnet Celebrity will blow it out of the room and they only have one 6V6 apiece.
It has a 6AT6 preamp (replaced by a 6AV6), 12AX7 PI, two 6V6s and a 5Y3. A schematic is available here Webster Chicago and interior shots here Webster Chicago PA Amp Model 166-1 - a set on Flickr . I actually can cut and paste here. I may try that with pics later.
All I have done is remove the two inputs wiring, which made no difference to the volume. I do wonder about a RIAA curve or some such as I know hooking up anything to a phono input on a HiFi receiver doesn't work well.
The amp sounds real good, great tone, but just not nearly enough volume for 2 6V6s.
Any suggestions as to what to start checking? I do want this beauty to play well.
Thanks
Thanks
