I have gotten the Traynor YGM3 amp with 3 inputs. I get very very low output nomatter where the volume setting is. All tubes are new and are lit. I have checked voltages and they are there except they are higher than what the schematic specifies. I checked all the caps and three or four (three musturd color) when tested, the cap meter tries to read the capacitance and at the end it displays "fuse". According to the cap meter manual, this would indicate that the cap meter fuse needs replacement but the fuse is ok. The subject caps are associated with tubes V2 and v6. I am thinking of replacing all the caps, do you think it is necessary to replace them all or just some specific ones. If some specific ones, could you suggest which ones are most likely the culprit. if you have any other recommendation I would appreciated.
The link to the service manual showing schematic and wiring diagram is below
http://traynoramps.com/downloads/servman/smygm3.pdf
Thanks for your help
Geofo
Geofo
