Hello folks,
Long post, but I'm trying to give a good picture of what I have measured and replaced so far.
I have a crate gx-212 that suffered a failure in the power amp section. When I received it all power transistors (Q12, Q13, Q15 and Q16) were shorted in one way or another.
One .33 ohm 5W emitter resistor was literally split in half, 3 others were open circuit.
I replaced Q12, Q13, Q15, Q16, all 4 resistors and then I discovered that Q10 and D11 had failed, and replaced them as well.
Testing on the light bulb tester still showed a high current draw. Measuring the base to emitter voltage on the power transistors showed that they were all being driven on by the opamp at IC3.
I also measured a significant voltage level coming from IC5. I replaced both IC3 and IC5, but still had the issue. No amount of adjustment of the bias control (AP1) would affect the output of IC3.
At this point I have removed IC3 so that I can take measurements without the current limiting light bulb.
+/- 40V looks good. +/- 16V looks good.
My suspicion is all around D29. I am seeing 7.6V at the junction with R53, 7.0V at the junction of R56. Now a .6 drop makes sense for a diode, but I would expect the value to be
centered around 0V, not at 7. I am also seeing 14.5 volts at the junction of R53, R54 and IC5 pin 7. IC5 Pins 5 & 6 are both 0V....
Since I have already replaced IC5, I'm scratching my head on this one...
Thanks in advance for any ideas you may have.
Dave
Crate GX-120, GX-212 Schematic.pdf
Dave
