I am trying to fix a Deluxe 112 Plus solid state combo amp. It makes a lot of buzzing noise when the reverb pot is turned above zero.
With the reverb pan connected, and rotating the reverb pot from zero to 10 the following happens;
Zero no noise, 1 to 3 is a squeal noise, then a thump sound, 4 to 7 buzzing, then a thump sound, 8 and above louder squeal.
I have cleaned the pot. I have measured about 0 to 48K resistance to ground at R57 when rotating the reverb pot.
I suspect the pot but I think it is possible there could be other issues.
The reverb pan measures 50 ohms at the input, 210 ohms at the output.
With the reverb tank disconnected I get only buzzing noise from 1 to 10 on the pot, getting louder as I go up the scale.
I do not have a spare pot that fits this amp but I do have another 48K pot I could use as a test. I was thinking of running jumper wires to the new pot (leaving the old pot in place set at zero).
Does this test make sense? If so I am not 100% sure where to connect the pins of the new pot. I suspect one wire to ground, one to R57, one to C31. If those are correct I am not sure what pins on the pot go where.
Any guidance and suggestions are greatly appreciated. Schematic attached.
Thanks! MC
Thanks! MC
